mpevans45069@gmail.com
#1 Posted : Sunday, March 6, 2016 11:49:08 AM(UTC)
What should I investigate when the water will dispense from the cold water dispenser on the freezer door, but the ice maker will not fill?
Can a bad inlet valve allow water to flow for the cold water, but stop the flow of water to the ice maker?
Note: tubing and water fill tune are not frozen. Both open for free water flow.
Inlet valve continuity tested at 0 ohms continuity.
Thank you!
red_snapper
#2 Posted : Monday, March 7, 2016 3:59:01 AM(UTC)
red_snapper
My Whirlpool has the same issue.
No answer about this since first posted Feb.23rd.
Good luck to us
