seanmahrt
#1 Posted : Monday, February 29, 2016 7:26:34 PM(UTC)
seanmahrt
I just replaced my water inlet valve because it was starting to leak and after the power was reapplied I could not select the water temperature (normal/high/sanitize). I know the events are unrelated and it lost "my favorite" settings that had the water temp set. I'm guessing it's a button problem, but wasn't sure if I needed to reset the controller. It was unplugged for about 24 hours.
Anybody know the pinout of the button harness (I'm an electrical engineer). I'd like to know if it's the button as you have to buy the entire bezel and I might be adventurous to fix it if it's not the logic board.
Sean
