Jimmie C. Smith
#1 Posted : Friday, October 30, 2009 5:26:34 PM(UTC)
Jimmie C. Smith
We recently used the self cleaning mode and since the oven comtroller says it is working but neither element heats up. does this oven have a thermal fuse, if so where is it located, if not what could be the problem?
Jimmie C. Smith
#2 Posted : Friday, October 30, 2009 5:28:39 PM(UTC)
Jimmie C. Smith
Correct, neither element heats up and they appear to be ok
#3 Posted : Saturday, October 31, 2009 3:01:54 AM(UTC)
Replacement parts for WHIRLPOOL RBS305PRS00 | AppliancePartsPros.com
Here is the tech sheet
http://www.servicematters.com/d...0Sheet%20-%208301758.pdf
Yes it shows a thermal fuse.
Note I just helped a person, the parts and tech sheet showed a thermal cutoff bo there was not one in the unit.
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Oven Heating Element Wire Repair (Oven Repair (including Ranges and Cooktops))
by JT5 11/22/2023 5:20:00 AM(UTC)
Frigidaire Oven Heats but Randomly Shuts off (Oven Repair (including Ranges and Cooktops))
by Guest 10/1/2022 7:32:55 AM(UTC)
old Wall oven heating element problems (Oven Repair (including Ranges and Cooktops))
by shelliejh 12/6/2018 12:16:51 PM(UTC)
Whirlpool oven heats at start but does not maintain temperature. (Oven Repair (including Ranges and Cooktops))
by steveb48 5/7/2018 10:06:27 PM(UTC)
Need oven heating element GE # J320B1AV (Oven Repair (including Ranges and Cooktops))
by railfan777 10/18/2017 12:48:58 PM(UTC)
Lower oven heating element does not heat up (Oven Repair (including Ranges and Cooktops))
by msterren 4/16/2016 8:45:48 AM(UTC)
KitchenAid KERC506HWH3 no oven heat (Oven Repair (including Ranges and Cooktops))
by luckyatva 1/23/2016 2:29:45 PM(UTC)
Oven Heating Problem (Oven Repair (including Ranges and Cooktops))
by Jman1 1/20/2016 4:33:59 PM(UTC)
Kitchen Aid KESC308LSSO Oven Heaters not Heating (Oven Repair (including Ranges and Cooktops))
by JARVMI 10/25/2015 3:31:44 PM(UTC)
Oven Heats Very Slowly (Oven Repair (including Ranges and Cooktops))
by egizzi 4/24/2015 9:52:38 PM(UTC)
Lower Oven Heating Extremely Slow (Oven Repair (including Ranges and Cooktops))
by winesalot 1/12/2015 11:07:00 PM(UTC)
Oven heats, but no display (Oven Repair (including Ranges and Cooktops))
by Rockytech 12/14/2014 8:51:36 AM(UTC)
Oven heat control panel only goes DOWN (Oven Repair (including Ranges and Cooktops))
by Joe Gemmill 12/1/2014 6:02:50 PM(UTC)
Frigidaire wall mounted oven heat to warm only (Oven Repair (including Ranges and Cooktops))
by vacrab 10/19/2014 10:08:50 AM(UTC)
