Hello all. Hoping someone can help. My oven of 6 years is taking forever to heat up. I saw a similar post but not all the same symptoms. Even when I tried the poweplus preheat feature it also slowly climbed to 350 and beeped that it was ready but it didn't seem hot so when I turned the oven off and did it the regular way it should have been ready at 350 but it was 200 and needed to climb to 350. The only thing I see that may be different (didn't notice before because i didn't look)is when I open the door of the oven after I turn it on the oven it appears (and this is after doing some research with the diagram of the oven) the burner under the baffle, bake Burner on the bottom is not igniting completely and only after some time passes does the entire burner shot out flames to heat the oven. Can someone help.
