AppliancePartsPros.com
Appliance Repair Help
KECC567RBL01 Cooktop; triple element not heating, replaced both switch and element
I have a glass cooktop (KECC567RBL01). When I turn on the triple element to any of its settings (single, double, triple), it will NOT heat up. I have replaced both the surface heating element AND the infinite switch and tested both with an OHM meter to ensure I wasn't replacing them with bad parts.
All other elements work fine.
What else could it be?? Please help!
