hello,
so after running the dryer during a blizzard, the dryer stopped heating (runs fine though)
dryer did not throw any error codes
checked everything for continuity, everything was fine except the thermistor... it had a reading of infinity
my question is, if the thermistor is bad, then why didnt my dryer throw an error code? (it is supposed to according to the manual)
any thoughts? should i be replacing my control board along with the thermistor? or do i just need a new thermistor.
