So I've been having this problem for a while. It creates too many suds on the initial fill causing suds to overflow over the top of the tub. Then, once it gets to the rinse cycle the timer will go all the way down to about 15 minutes then go back up to the start of the rinse cycle again in an endless loop. I'm not sure what the problem is.
I've already changed the control board thinking it was a timer issue. I've changed the water inlet valve thinking it was a water flow issue and I've changed the pressure switch and tubing thinking it was a level sense issue. I'm out of ideas so any help would be appreciated.
