AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Dryer stopped heating, everything else working.
Dryer apparently stopped heating. Put a load in yesterday morning when I left, came home a few hours later and it was dry. Put another load in and later that evening when I went to remove it everything was still wet. Restarted it and let it run 10 minutes and still no heat. Changed all the buttons around and then set back to normal heat, turned it back on still no heat. I have an idea that it is probably one or more of 4 or 5 parts but I wanted to try and narrow it down to the most likely one or two without having to test every single one first. What part (parts) do you think I should check/replace first? Igniter, gas valve solenoid, thermal fuse, cycling thermostat, high limit thermostat or???? Thanks. Keith.
Dryer Repair
