catsanddogs
#1 Posted : Saturday, February 6, 2016 4:52:40 PM(UTC)
catsanddogs
The 3 single size cooking points will turn on but turn off immediately. If I raise the setting they will stay on for a second or two longer, but then turn off...turn on for a second or two, turn off and so on. If I raise it to high they will stay on. The dual size burner works better but not perfect. Could this be an issue with the Control Board as they all failed at once?
