Here is the problem. The fridge (top) cools fine and seems to be working fine. The freezer (bottom) cools fine then for no reason will decide to warm up to as high as +10 C.
I've kept thermometers in the fridge to track the temperature of both freezer and fridge. The fridge is set at #4 and is staying in the 4-6 C range but the freezer at #6 goes from -22 C up to +10C. It then re-cools down to -20 leaving behind ice and frost.
All I know is the seals are fine. Thanks
Bumping this as I totally updated my post with new info from monitoring the situation.
