AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Fan turns on when door open for frigidaire Microwave
I think I have two separate problems. 1. Fan turns on when door opened. Nothing else turn on except the internal fan. 2. The turn table does not run smoothly . It runs but seems speed is not even.
Originally Posted by: rbsolanki  I think I have two separate problems. 1. Fan turns on when door opened. Nothing else turn on except the internal fan. 2. The turn table does not run smoothly . It runs but seems speed is not even. Hello Rbsolanki, This is most likely a bad door switch causing the fan to run. There are two Part number: AP3769802
and one Part number: AP2148482
. It is recommended to replace all three at the same time. The turntable parts should be checked for resistance to rotation. If no issues are located, you will have to either replace the motor Part number: AP3770128
Microwave Repair
