Our water line into our water filter reservoir is leaking. I cannot tell if the actual line has a hole in it or if it is the connection of the line into the reservoir. I want to replace either the reservoir or the line or both. First, I am scared to remove the line from the reservoir. Will I damage it? Forgive my ignorance. If it is just the line, can I go to my local Home Depot or Lowes and get a replacement? if it is the reservoir, where can I get a replacement reservoir? is there any web sites out there with some help for replacing a reservoir or other parts on a refrigerator?
Thank you for taking the time to read this.
