WTAIII
#1 Posted : Thursday, January 21, 2016 6:06:45 PM(UTC)
WTAIII
On the Drain/Spin cycle, washer will pump the water out, rotate left and then right 2 or 3 times then beep several times and the control panel goes dark. Verified lock light is lit and door is locked. Any ideas on what is causing the high speed spin to fail when the agitation is working?
RebrettaV
#2 Posted : Thursday, January 21, 2016 6:47:02 PM(UTC)
RebrettaV
http://manuals.frigidaire.com/p...df/webster/134542000.pdf
Sure sounds like the door switch. I'd try out the tests related to the switch to determine if you have a bad switch or control board.
Washer Agitates but Won't Spin, Drum Dropped (Washer Repair)
by dagwinn 8/17/2017 4:47:57 PM(UTC)
Admiral aav7000aww agitates but won't spin (Washer Repair)
by chenzzo 12/29/2016 9:06:46 AM(UTC)
whirlpool washer agitates but won't spin (Washer Repair)
by vinzant15 2/7/2015 12:16:09 AM(UTC)
Roper washing machine agitates but won't spin out. (Washer Repair)
by Ktlyn129 7/20/2014 4:13:09 PM(UTC)
by nmckaskle 9/28/2012 5:34:58 PM(UTC)
GE washer agitates but won't spin (Washer Repair)
by nicolle_m 5/17/2012 5:57:01 PM(UTC)
wirlpool topload agitates but won't spin or pump motor hums (Washer Repair)
by curly33333 5/16/2012 6:51:35 AM(UTC)
GE Washer agitates but won't spin (Washer Repair)
by splitune 11/25/2011 1:26:23 PM(UTC)
top load fills&agitates but won't spin/drain (Washer Repair)
by mellnyy 8/28/2010 8:16:15 PM(UTC)
washer fills and agitates but won't spin or drain (Washer Repair)
by Jim Bags 7/6/2009 4:37:15 PM(UTC)
by Bab 2/17/2009 7:49:43 AM(UTC)
Agitates But Won't Spin (Washer Repair)
by vze1kobm 5/13/2008 7:14:33 AM(UTC)
Kitchen Aid Washer Agitates But Won't Spin (Washer Repair)
by leroypg 10/16/2007 8:31:06 AM(UTC)
washer agitates but won't spin` (Washer Repair)
by mls6089 10/12/2007 7:34:53 AM(UTC)
