riki
#1 Posted : 9 years ago
riki
How does one take off the oven door? It will not lift off at all so I'm not sure what to do next. Otherwise, I can't get to the lower element screws to remove them and change out the element (burned out) Any ideas? :confused:
#2 Posted : 9 years ago
Below is a link to an operators manual for a JBP35BHCT.
Yours is probably the same
http://products.geapplia...&Name=49-80494-1.PDF
