no flashing led correct voltages at all pins no error codes on field service mode checks MODE SHIFTER COIL TEST SHOWS NO CONTINUITY thanks jeff
If you are not getting error codes and you have done the reset process it is the motor/inverter that is probably the problem. If you buy the part from this site and it does not fix the problem you can return it. But it is an expensive repair and you might want to just replace the machine with a nice no frills, no electronics top loader.
