I have a kenmore series 300 top load washing machine and it's seems to run continuously through all the cycles over and over. I've tried different settings and load sizes but it always keeps running. Help?
If the water runs even after you unplug it then the valve is stuck open and the valve assembly needs to be replaced. If not and it only runs water when it is plugged in and turned on you may have created a siphon on the drain hose by jamming it in the drain with no air allowed, or you may have a malfunctioning water level switch and/or control unit.
