Washer will spin & drain but will not agitate.
You need to operate it with the front panel off and see what is happening when the machine is in agitation cycle. If the motor is turning but the transmission is not than the transmission is likely the problem. If the motor is not turning it may be the control units since its spins which would imply the motor is okay.
