kbjunkfan
#1 Posted : Saturday, January 9, 2016 5:11:18 PM(UTC)
kbjunkfan
Hi Everyone,
Thank you in advance for your assistance!
Kenmore 665.12093K210 – about 3 years old – just stopped working.
The dishwasher starts and water will pump in (and later drain), but it will not complete all cycles. For example, it will start to fill with water and go through that cycle, but it will not move onto the wash. At that point the dishwasher goes silent, but you can hear—I think—the timer clicking forward as it progresses through the cycle without anything really happening. Tried all different modes (pots and pan, normal, etc.) and it’s the same result.
It will drain out as well, so there is something causing it to not kick into the true wash cycle. Heating element also seems to be working okay, so I am thinking that it could be related to the control board or something else electronic.
Again thanks for your thoughts and help!
KB
#2 Posted : Sunday, January 10, 2016 6:04:16 AM(UTC)
See the attachment for the tech sheet
Check if the wash motor is getting 120 volts when it should.
If not then remove power from the unit and check F8 and the wires from the control board to the motor.
If it is getting 120 volts then probably the motor is toast.
