Longknife
#1 Posted : Wednesday, January 6, 2016 2:05:36 PM(UTC)
Longknife
Having problems with my 3 year old Bosch dishwasher. (SHE3AR55UC) All the info I have found deals with the older models. When the start button is pushed the pump starts . runs a little while and then the clean light comes on and the washer shuts down. It never does fill. I have checked water supply, elec. supply, replaced water valve and tested float switch. When running diagnostics it fills, runs, empties and clean light comes on but it never gives me a code to check. These newer ones do not have a read out, they just turn on a light and then you check manual to see what it means...but NO light??? I THINK I know what it is....but not sure....any opinions?
Longknife
#2 Posted : Sunday, January 17, 2016 9:47:43 AM(UTC)
Longknife
An update on this problem, I "chatted with a pro" who advised that the control module was likely the problem. I ordered it and installed it but that didn't cure it . The washer still will not fill---BUT it fills, runs and empties on the test cycle. When the test cycle is running the #1 test light flashes during the test cycle, then it shuts off and the clean light comes on....HELP!!!!
