jeffsdad
#1 Posted : Monday, January 4, 2016 2:49:43 PM(UTC)
jeffsdad
I am having trouble with my whirlpool washer. It won't start. When it stopped working it made a buzzing sound. I know it's not the lid switch. So I purchased a new timer from you guys. After installing it, it still makes the same buzzing sound. I have checked the outlet and the breaker. I also visually checked all the connections and wires. It fills with water and then nothing. Just the same buzzing. I have even tried kicking it. Please help. Thank you for this free repair forum. Sincerely, jeffsdad
sidfink43
#2 Posted : Tuesday, January 5, 2016 3:40:42 PM(UTC)
sidfink43
See what happens when you manually move the timer to rinse or spin. If it still does not work then this suggests the motor or the capacitor. It is very rare that the capacitor goes but easy to check out. If the capacitor is okay then the motor is the likely suspect and given the age of the machine in that case replacement is probably the better option.
washing machine repair (Washer Repair)
by jeffsdad 1/4/2016 2:56:40 PM(UTC)
by robert joyner 3/29/2014 11:23:44 AM(UTC)
by robert joyner 3/29/2014 11:23:41 AM(UTC)
by maindrain 5/8/2012 9:29:13 AM(UTC)
Washing Machine Repair (Washer Repair)
by CAC 1/5/2011 9:48:17 AM(UTC)
Washing Machine Repair (Dryer Repair)
by avery208 12/6/2010 11:02:19 AM(UTC)
by sbell63@rr 10/1/2010 4:53:04 PM(UTC)
whirlpool washing machine repair (Washer Repair)
by igtaylor3@msn.com 7/21/2009 6:39:44 AM(UTC)
Washing machine repaired (Washer Repair)
by noi 7/6/2009 3:03:53 PM(UTC)
Washing Machine repair (Washer Repair)
by dqf 9/24/2008 5:29:18 AM(UTC)
