Door was left open. When we found it light was on but compressor wasn't running. Unplugged unit and replugged and nothing - no click, no hum. Starter relay or something worse?
Sorry but I cannot find any info on the given model number. Tried here, Sears and Frigidaire. Please check it. Find your model number - AppliancePartsPros.comIf it is the type of freezer that uses an evaporator and a fan, was the fan on If no then the compressor start relay is probably niot the problem If the unit uses a mechanical defrost time perhaps the unit is in a defrost cycle. How long did you wait. Defrost usually takes about half an hour. |
THIS FORUM IS DEAD!!!!!!! |
Okay try LFFU1765DW4 No fan, No clicking, no hum from compressor, just the light seems to work. Did notice thermostat doesn't have that "click" when it goes from off to full on. Also notice a slight"ozone' smell when we first found freezer open. Left freezer unplugged overnight before plugging back in.
I turned the defrost timer about a quarter turn and fan has come on but compressor doesn't come on. I do hear a very quiet rapid clicking but it doesn't seem to be compressor making that sound.
