JohnBremer
#1 Posted : Tuesday, December 15, 2015 11:26:00 AM(UTC)
JohnBremer
Hi-
Our washing machine overflows and the water won't shut off with the off button or pulling the plug. Think it might be the solenoid.
How difficult would that be to replace and do you carry that part? Thanks!
sidfink43
#2 Posted : Wednesday, December 16, 2015 4:13:48 PM(UTC)
sidfink43
Yes, if the water continues to run after power is shut off that almost certainly confirms that the water valve assembly needs replacing. Here is the part and yes it is an easy repair. Just unplug the old assembly, take out the screw(s) that hold it in place and put in the new one.
Part number: AP3861119
GE washer is overflowing (Washer Repair)
by Peetsi 11/9/2011 1:54:24 PM(UTC)
GE Washer is overflowing (Washer Repair)
by washerman 4/6/2010 4:33:11 PM(UTC)
