jamie_pancake@yahoo.com
#1 Posted : Wednesday, December 9, 2015 4:02:33 AM(UTC)
The refrigerator section will only go down to between 46-50. The freezer is -2. There is no frost on the evaporator nor any ice blocking the vents. The fan is working and the service mode test says that the damper is opening and closing and I feel air coming out of the refrigerator vents. The frost pattern seems OK. I replaced the thermistor in the refrigerator but it didn't help. The condenser fan runs and is clean. What is causing this problem?
