Hi. I have an old RVC36 that the PCB has a burn spot and won't work anymore. I read is spending $160 bucks in changing the PCB, I found another model, CABP3, do you know if I can just remove old one and replace it with this CABp3? Are the measurements and specs compatible? Any ideas you can give me? :confused: :confused: :confused: :confused:
