drier has heat all the time one the air fluff cycle everything seems to be working fine everywhere else
Here are your parts Parts for Maytag LDE9606ACE Dryer - AppliancePartsPros.comCan you regulate the temperatures in the other cycle types. If not then it may be a grounded element. If the temperature is can be regulated the odds are that it is a timer problem. Note that I cannot find an actual wiring diagram so am guessing. |
THIS FORUM IS DEAD!!!!!!! |
