I have the new spider arm on, then noticed a broken plastic baffle in the front half of the drum assembly. The worn plastic cover is in front of the 'detergent fill tube'. 1.Do I have to replace Part #'1' [Front Drum Assmbly"]? It is very expensive! 2.What if I don't, will water backup into the fill tube & soap dispensor? :confused:
