Woodym1946
#1 Posted : Thursday, December 3, 2015 5:12:03 AM(UTC)
Woodym1946
I have a Whirlpool Dryer Model LEQ9508PW1 that recently died. Was working fine then nothing...nothing at all. Even the light in the drum doesn't work. Chatting with the repair pro it was determined to be the thermal switch. That was replaced. Nothing happened. Then possibly the push to start switch and I have that removed. Trip to the local appliance parts house and they didn't have one. I have checked and have power through the terminal block and to every spade connection that I can reach with a probe. I still need to buy a new push to start switch, but also realize that I may need something additional to make this work. Any suggestions will be appreciated.
#2 Posted : Thursday, December 3, 2015 7:28:11 AM(UTC)
Parts for Whirlpool LEQ9508PW1 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Unless the interior light going off is just a coincidence it will not be the push to start switch.
It could be the door switch re: the contacts are not closing.
It can be checked with a meter using resistance.
If you put the timer mid scale of a heated timed dry cycle and the timer does not advance this would also point towards a door switch or a power problem.
Could also be a timer problem.
I do not know how you checked for power but you must check that there is 240 volts between L1 and L2. This is the only way to be sure you have both supplies when the unit is plugged in.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Good Morning! (Dryer Repair)
by David Norwood 11/16/2009 12:26:10 PM(UTC)
