billchapjr
#1 Posted : Wednesday, November 18, 2015 4:28:07 PM(UTC)
billchapjr
I'm working on a Samsung Range Convection oven. Model FTQ387LWGX/XAA. Customer complaint was that oven taking to long to preheat, and Broiler not working. The broiler element is ok and the oven sensor checks out ok has correct resistance.
Main control board seems to be working it cycles the elements from top to bottom but no power to broiler element. I have power to on leg but not to other. I checked for proper voltage at the Sub PCB oven control board.
I replaced the board and the sensor. Buy the way I never got lock indicator and any error codes and all the motors are operating.
After replacing the board I got an E28 error code which said open sensor, also got a code EOE which is the door lock control and none of the motors worked.
so I reinstalled the old board and everything worked like before except no broiler element power.
I think I have a bad Sub PCB board that I ordered. I dont think the main board is the problem. Am I right or does any one think its something else.
I appreciate any help on this.
Bill
