toddo03
#1 Posted : Tuesday, November 17, 2015 1:27:22 PM(UTC)
toddo03
Hello Everybody,
I have been fighting an issue with my Kenmore range shutting off when preheating and baking. The stove top work perfectly. The oven will shut off and display a E0 F2 error code. This led me to look at the touch pad as the problem. I have replaced it but the the problem still exists. Originally the problem was intermittent but now it happens instantly when using the oven. When tearing into the unit deeper I noticed the R1 resistor on the "power supply board" pt#8273535 was burnt. I replaced the board and it fixed my problem but immediately the resistor was so hot it burned the coloring off it. I unplugged the board to prevent damaging it. I checked the transformer voltage and it was slightly out of reange so I replaced it also, but this did not fix it. I assumed the main oven control board must have a relay locked on so it was replaced. Still the same problem exists. Any help would be greatly appreciated.
Todd
