cindysue62
#1 Posted : Monday, November 16, 2015 12:38:10 PM(UTC)
cindysue62
Rank:: Member
My husband is trying to fix this washer for our daughter it fills washes but won't drain or spin out and he said it looks like it has lost oil or has leaked oil. And do you or can you replace the oil? And if so what do you use? So he says it fills washes but beyond that it stops!
Thank you very much
sidfink43
#2 Posted : Thursday, November 19, 2015 4:29:41 AM(UTC)
sidfink43
You did not say if it agitates. If it does then your symptoms suggest a lid switch problem.
If the seal on the transmission is bad it will leak oil. You would need to remove the transmission, an easier job then it sounds and replace the seal and the missing oil. 90 weight oil should do the job, but you can all the parts department of APP for advice and the parts.
Roper washer RAL5144BQ1 (Washer Repair)
by Nanabkim 2/16/2024 2:16:15 AM(UTC)
Roper washer will not run (Washer Repair)
by Guest 12/10/2023 10:53:47 AM(UTC)
Roper Washer Cycle not Going Past Wash (Washer Repair)
by Guest 5/31/2022 7:14:14 AM(UTC)
Roper Washer RAX6144EW1 (Washer Repair)
by mtwheeler 6/14/2021 2:55:09 PM(UTC)
Roper washer RTW4640YQ1 out of balance (Washer Repair)
by seagypsy 10/3/2020 5:00:03 PM(UTC)
Roper Washer spin ballance banging wobbling (Washer Repair)
by Braum 9/29/2019 7:51:52 PM(UTC)
Roper washer will agitate instead of filling at the beginning of the cycle (Washer Repair)
by wilkimtur1 2/11/2018 7:56:25 AM(UTC)
roper washer wont go to rinse cycle (Washer Repair)
by stevencurtiss 2/25/2017 7:19:56 AM(UTC)
Roper washer making awful noise during agitate and spin (Washer Repair)
by Michaelk24 2/8/2017 6:00:25 PM(UTC)
Roper Washer no Start (Washer Repair)
by bellmd 1/21/2017 6:08:14 AM(UTC)
Roper Washer Walks Counter Clockwise (Washer Repair)
by RunawayRoper 10/14/2016 3:47:34 PM(UTC)
Roper washer (Washer Repair)
by Mike Newberry 8/6/2016 7:44:22 PM(UTC)
Roper Washer spins but doesn't spin enough water out (Washer Repair)
by tomanypups1 7/24/2016 7:14:54 AM(UTC)
Roper washer fills with water then nothing else (Washer Repair)
by faunwin12 5/14/2016 6:20:49 AM(UTC)
Roper washer not completing rinse cycle (Washer Repair)
by Drumm3rboy07 1/1/2016 9:19:17 PM(UTC)
