osceolakings
#1 Posted : Friday, November 13, 2015 9:15:49 AM(UTC)
osceolakings
Our duet has been having problems with the final spin. We did the code procedure and determined that the pump was faulty, we replaced it. It helped the problem but still wasn't 100%. The new code told us it was the CCU, replaced it. As long as we were in there, we also replaced the belt. Again it helped, but didn't fix it entirely. Now we can not get it to throw a code. We have unplugged it to reset, twice and run the code procedure but it goes through the whole procedure and no code.
We run a test w/o clothes and it works fine. Run a light load, and it almost spins the water out. Run a heavy load (jeans) soaking wet at the end.
Your insight would be appreciated.
:confused:
