Vicki Vail
#1 Posted : Sunday, November 8, 2015 5:24:33 PM(UTC)
Vicki Vail
My dishwasher does not drain. We have an excessive amount of standing water on the bottom of the dishwasher (not immediately after a cycle however). I can manually drain it by starting a wash cycle and cancelling it. It also appears to drain on its own at the end of a cycle.
I have checked and cleaned the line (using a power washer) from the dishwasher to the garbage disposal.
I have removed the basket, and cleaned out very minimal debris.
I have used two bottles of Draino.
I have used the baking soda, vinegar and hot water mixture.
Is it possible I need to replace the pump? Would it be draining at the end of a cycle or manually if the motor was bad?
#2 Posted : Monday, November 9, 2015 2:05:44 AM(UTC)
[COLOR="Blue"]I have used two bottles of Draino.[/COLOR]
If you put this is the dishwasher this was a very bad idea.
It could eat some of the parts also not very good for you if Draino residue ends up on your dishes.
I doubt it.
No.
There is a proviso here because it depends on how long the drain cycle is.
How do you know that it is not draining during a cycle?
[COLOR="Blue"]We have an excessive amount of standing water on the bottom of the dishwasher (not immediately after a cycle however)[/COLOR]
Could you clarify what the above means.
The way I interpret it is that immediately after a cycle there is no water in the tub but later on there is.
If this is correct then it is probably not a drain problem but could be a water valve leaking problem or water from the house plumbing draining back into the unit which can usually be fixed by re-positioning the drain hose
