I have a 1948 Frigidaire stove that is my cooking stove. Recently the clock stopped working and i find the right hand oven (there are two) does not heat up to temperature. It gets warm but not above 200 degrees. I am thinking the problems may be related and wondering if there are fuses or something I can check out to repair?
Yes most older stoves have fuses for the elements etc. Often the top of the control panel is hinged and they are under there.
You may have some luck if you Google " Frigidaire antique stove" |
THIS FORUM IS DEAD!!!!!!! |
