macd2x
#1 Posted : Sunday, November 8, 2015 7:29:26 AM(UTC)
macd2x
I found a small leak under my dishwasher and traced it to the area under the float. After removing the float, I found the standpipe was loose and must be the source of the leak. There is no gasket under the nut.
My first question: should the flat gasket be assembled inside the tub or under the tub? If it is supposed to inside the tub, then I'm missing that part.
My second question: the sound dampening pad behind the toe plate has gotten gross from the leak. What's the part number to replace that?
#2 Posted : Sunday, November 8, 2015 9:30:30 AM(UTC)
Click on the part's picture for more info on it.
According to the Q&A the gasket goes inside the tube.
Part number: AP3181006
It is a good idea to give it a light coating of grease etc. before installing it. This should prevent the nut from twisting it when you tighten it.
As far as the sound dampening, look in section 1 of the parts.
Looks like it may be item 7 Pad-Ins. That is if I assume Ins stands for insulation. Probably best just to get the whole kit and caboodle (item 5).
