I came home tonight to find the freezer defrosting and the fridge side too warm.
It has power. The lights come on. I don't hear anything running. I've had to repair this thing so many times, but the new symptom this time is: the electronic temp adjust to set each side to cold-coldest (1-7) just has - where the numbers should be, and it doesn't respond to the up and down buttons.
Any pointers on what to test first, with that symptom in mind?
Thanks.
Here are your parts Parts for ASD2628HE - AppliancePartsPros.comYou seem to be missing the last digit so you will have to choose a unit from the Matching Model Numbers section. See the attachment for the tech sheet. Try unplugging it for a few minutes to see if it will reset itself. If no go then try getting into the diagnostics. |
THIS FORUM IS DEAD!!!!!!! |
