dan1520
#1 Posted : Monday, November 2, 2015 10:25:12 AM(UTC)
dan1520
In our front loading washer, the front bellow tub seal doesn't seem to drain the water after a wash. After a wash, approx. 1 in of standing water is still present on the bottom of the boot. It takes a long time for it to drain. Is the drain clogged? If so, how do I unclog it? What chemical to use? How about blowing compressed air into the drain?
Any assistance would be appreciated.
Thanks in advanced.
sidfink43
#2 Posted : Wednesday, November 4, 2015 12:05:08 PM(UTC)
sidfink43
You probably have junk accumulated in the drain pump/hoses. Take off the lower service panel and clean out the pump, that will likely fix things.
