mvuille
#1 Posted : Sunday, November 1, 2015 8:09:28 AM(UTC)
mvuille
Takes longer to dry large loads or heavy items
in normal loads (e.g., jeans). This started recently.
I have already checked:
- Exhaust is clear and air flows freely
- Tore-down the dryer and cleaned all lint
(there wasn't much)
- Checked operation of the thermostat,
it is cycling at the rated temperature.
- Checked operation of the bias heater,
the thermostat is cycling at lower temperatures
in the "medium" and "low" heat settings
- Checked the heating element, ~ 9.7 ohm
resistance
Does anyone know whether this is the correct
resistance for that heating element?
The dryer is squeaking a lot and I need to replace
the drum rollers and idler wheel. Could that somehow
affect drying time?
Anything else I forgot to check?
Thanks in advance
MV
#2 Posted : Monday, November 2, 2015 2:22:40 AM(UTC)
I cannot find any info on the given model number.
Trued here and the Sears site.
Please check it.
Note that if this is not a USA unit I probably will not be able to find info on it.
Your heater resistance looks OK but I cannot confirm this.
Check if the drum speed is the same with light and heavy loads?
If it is slower then that will effect dry times.
Did you check/clean the blower wheel?
mvuille
#3 Posted : Monday, November 2, 2015 5:19:18 AM(UTC)
mvuille
Double-checked model 110.8820293
This was purchased from Sears Canada
Will check drum speed as you suggest
MV
#4 Posted : Monday, November 2, 2015 6:22:49 AM(UTC)
OK I will not be able to find tech info on this unit.
The Sears Canada parts site stinks.
I know because I am also Canadian.
