ran
#1 Posted : Thursday, October 29, 2015 4:49:42 PM(UTC)
ran
i put the new evaporator fan motor on plug in frig i dont hear it running
#2 Posted : Friday, October 30, 2015 1:50:51 AM(UTC)
Is the compressor and it's fan running?
If not then give it half an hour or so as you may be in a defrost cycle.
Is the reason you replaced the evaporator fan, that the old one was also dead?
Before you replaced the fan did you check that there was 120 volts across it?
ran
#3 Posted : Friday, October 30, 2015 5:01:10 AM(UTC)
ran
Yes it was not running but no I didn't check for 120
ran
#4 Posted : Friday, October 30, 2015 5:03:11 AM(UTC)
ran
But I did short it out by trying to remove ice build up on it
#5 Posted : Friday, October 30, 2015 10:11:12 AM(UTC)
I would check that there is 120 volts at the plug.
The compressor and its fan should be on when you do this.
When you shorted it out you may have blown the defrost board.
Note that there is a wiring diagram included with the parts breakdowns.
