Hi, I have aFrigidaire dishwasher that leaks at the bottom between the door and the tub of the dishwasher. I have replaced both the bottom-door seal and the tub gasket without improvement. I am certain that I installed the bottom-door seal correctly. I took the front panel off the door and ran the dishwasher and could see that water sprays out from the open space in the middle of the seal that doesn't have a yellow strip. This water then drips down the inside of the door and leaks onto the floor. I can easily slip a piece of paper into this opening even with the door fully closed. I don't know if there's another missing piece that I missing or if the dishwasher is just defective? This dishwasher is relatively new - the seal and gasket I replaced did not look used at all. Any idea why it's still leaking???
