Problem started with stopping at spin cycle. Was able to "force" cycle to finish by cancelling regular cycle and starting drain and spin cycle. In mean time, ordered and replaced actuator. Starting completing cycles for few days then problem started again. So replaced the lid lock assembly. First run after replacement stopped at spin cycle again. Was able to finish by cancelling regular cycle and starting drain and spin cycle. Now when start lid does not lock and sensing light stays on along with humming noise. After several minutes, sensing light starts blinking and eventually goes off. Ran diagnostics and error code was F0E0 which doesn't make sense. There is no consistency to the problems. Seems to be sporadic as to which problem occurs and when. Suggestions please.
When things like this happen it is usually the electronics, so I would try replacing the control unit. If you buy from this site and the new control unit does not fix the problem you can return it.
