dominatus
#1 Posted : Wednesday, October 14, 2015 11:33:39 PM(UTC)
dominatus
My 5 year old Kenmore (253.6480240e) refrigerator hasn't been working right for awhile now. It kind of gradually happened in that the temperatures in the fridge have slowly gotten warmer (still cool enough to keep milk from spoiling). I mainly noticed the freezer sometimes wouldn't keep ice cream frozen.
But I later noticed that the refrigerator hadn't been running for hours one day, although plugged in and fridge light on when door opened. I learned that the refrigerator might be stuck in defrost. The refrigerator had been making a ticking sound for well over a year. I never gave it much thought as it had always done that from time to time and I had read that it was the defrost timer and never looked into it further as the refrigerator had been fine at the time. After manually advancing the defrost timer with a screw driver, the refrigerator and compressor came right on.
However, the issue of the refrigerator not cooling still persisted. After doing some more research I learned that another sound I had been hearing for awhile - an occasional popping noise from under the refrigerator was not normal. I learned that sound was likely (and indeed was) coming from the starter.
Admittedly, I really have been quite ignorant with all this. I have since ordered (from this site) and installed a new defrost timer, starter and run capacitor. The refrigerator has been cooling fine, however I am still hearing occasional popping sounds coming from the brand new starter. Does anyone know why this could still be happening? I assume there is something wrong with the compressor.
#2 Posted : Thursday, October 15, 2015 6:57:09 AM(UTC)
[COLOR="Blue"]Does anyone know why this could still be happening? I assume there is something wrong with the compressor.[/COLOR]
Tes I agree with you it is very unlikely that the popping is coming from the starter since you have replaced it.
Check the compressor mounts perhaps it is a problem with one of them.
Could also be the compressor itself, please see the below.
This is copied from this site.
http://www.applianceaid.com/refrigerator-repair-help.php
My fridge makes a bang noise when it shuts off:
Sorry to say most times this is a faulty compressor. A compressor is a electric motor and pump mounted from springs inside the black dome, if one of these springs stretches or breaks the motor and pump hits the outer casing dome and bangs when it shuts off. Other things to check for, tubing touching one another, something fallen behind the fridge, condenser fan motor blade hitting something, defrost condensing pan out of place.
