Hello, I'm hoping for some help diagnosing a problem with our gas dryer! I have skimmed through some of the other threads but I am a novice and have multiple symptoms and I'm not sure if they're connected or not. Thank you all so much for the help! Symptom 1: We first noticed the dryer not heating after doing multiple loads of laundry back to back...i.e. it would do fine with the first load and if we started another load it wouldn't heat for long. If we waited until the next day or something like that, it would heat again. This has progressed into the dryer not heating at all anymore, even on the first load. Symptom 2: Not sure if this could be related, but we have also noticed that the dryer would keep running after the clothes were dry. For example we put on a load before going to bed and woke up in the AM with the dryer still running, cold inside, but the clothes dry. I recently put a new belt in this dryer so I'd love to fix it again if possible. Can anyone help me diagnose the problem? I'm handy with a DMM or whatever other tools necessary. Here's the make/model info:
