My dishwasher door is crooked / not lined up with the edge of my countertop. We had a problem with the machine a couple of weeks back, which was fixed by a repairman, and the door has not been even since. Any thoughts on how I can realign this? The machine is not leaking, it's just driving me nuts. Thanks. mreesele attached the following image(s):
Here is a link to the install manual. http://www.whirlpool.com/digita...ions%20-%20W10321621.pdfYou will have to figure out how the dishwasher is attached to the floor or cabinets. Could be that it is not attached to anything. Remove the kick plate and look to see if something (drain line etc.) is holding the one side from pushing bach under a cabinet. |
THIS FORUM IS DEAD!!!!!!! |
