Bill Berman
#1 Posted : Friday, October 2, 2015 3:58:27 PM(UTC)
Bill Berman
Get constant flashing of heat probe indicator front left of oven even though not plugged in. only way to stop constant beeping is to turn house breakers off. Any clues at whats wroung.
#2 Posted : Sunday, October 4, 2015 5:02:51 AM(UTC)
Parts for KitchenAid KEHC309JSS4 Oven - AppliancePartsPros.com
Could be that the probe receptacle is dirty inside.
If possibble I would disconnect the probe at the control board.
Then plug the unit back in or restore power and see what happens.
If you still have this problem the control board is probably bad.
Guest (4)
