I'm renting an apartment that has a Jenn-Air w216 model self cleaning radiant bake oven. I have the use and care manual, print date 1989. I've been in the apt for 2 yrs with no problems til now. Top oven is running about 50 degrees cool. Bottom oven is running about 25 degrees hot. I don't see anything in the manual about re-calibration. Any suggestions? Thanks!
I cannot find a picture of the control knobs so the below is a guess.
Gently pull the knob off. On old units often the nob/setting can be adjusted on it's back side. |
THIS FORUM IS DEAD!!!!!!! |
