Dryer won't shut off. Thinking the timer is bad.
Does it do this in both timed dry and auto modes?
Does the timer advance? |
THIS FORUM IS DEAD!!!!!!! |
Yes it does it in all cycles. But does advance but it won't after it gets to the end of the cycle
Yes it does sound like a timer problem as it is going past off.
You could check the timer with a meter at the end of cycle to see if a contact set is not opening, see the timer chart. |
