pswest
#1 Posted : Wednesday, September 30, 2015 8:23:46 AM(UTC)
pswest
my dryer originally would not stop at the off area, it would then continue on thru several cycles until you stopped it. Now it will not run at all. Is this the timer? We already tried the thermal switch
#2 Posted : Thursday, October 1, 2015 12:36:51 AM(UTC)
Parts for Estate EED4400WQ0 Dryer - AppliancePartsPros.com
Here is the wiring diagram
http://forum.appliancepartspros...ing-properly-eed4400.pdf
If it has an interior light does that work?
If not it is probably an electrical problem.
It is the L1 to Neutral side that runs the motor and light.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If OK
Check the BK to B contacts on the timer with a meter. Should be 0 ohms in any run mode.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
Estate Electric Dryer - No Heat (Dryer Repair)
by Porkface 5/26/2012 1:49:09 PM(UTC)
by Porkface 5/26/2012 1:47:21 PM(UTC)
Whirlpool Estate Electric Dryer (Dryer Repair)
by Jefnir 6/16/2011 4:55:36 AM(UTC)
whirlpool estate electric dryer takes two or three times to dry (Dryer Repair)
by huckfinn979 8/21/2010 9:33:28 AM(UTC)
