ameyer0423
#1 Posted : Tuesday, September 22, 2015 6:01:04 AM(UTC)
ameyer0423
My Whirlpool Stove top and Oven will not heat up. I was using two burners on the stove top to boil water and cook meat when both stopped heating up completely. I checked the other two burners and found that they were no longer working either. I then attempted to heat up the oven and found that it would not heat either. The digital displays and lights continue to work however the stove top and oven will not heat up at all.
Any suggestions on what could be wrong would be greatly appreciated.
Thank You!
#2 Posted : Wednesday, September 23, 2015 1:06:14 AM(UTC)
Parts for Whirlpool WFC310S0AW0 / Range - AppliancePartsPros.com
Since the stove top and oven elements went out I would check the power.
They all require the full 240 volts.
Whirlpool problems (Dishwasher Repair)
by jwr 8/4/2008 2:45:02 PM(UTC)
