My wife said our Samsung Range does not work. It is 18 months old - past the warranty but far too young to be failing. Nothing in control unit works - no lights, no beeps. LEDs flashed when I removed power cord but do not go on when I plugged it back in. What should I replace - the Control SUB, Pcb Main or Switch Membrane Panel?
I have a Samsung gas range. The burners on top work, however the display does not, it will not allow me to turn the oven on or any other function. The only display it does show is (5E), I guess this is an error code. Please Help.
