My coin operated Kenmore washer will just continue to spin until the lid is lifter. Any suggestions as to where to start looking?
Those of us who reply on this site normally are not familiar with coin operated machines, but this problem sounds like it is independent of the coin operations.
Since it works correctly and does not have a mechanical problem the issue is likely with the timer/control unit. Try changing it out and see if that helps things.
Thanks I will try that out and see.
Great, let us know how it turns out.
